Problem with Peugeot 306
17 years 9 months before #1778 by manual-mecanica
Manual-Mecanica Response on the subject problem 306
Another question, I change the filters and all that myself and when putting the diesel filter you have to bring any purge or something? xq I didn't exhaust it, I change it and point, in case I had that what do you see ???
Another thing I plan to remove the admission collector to remove all the fat inside, which has enough, will you notice many improvements? Can you also clean the intercooler? How should it be about? thank you.
17 years 9 months before #1779 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with Peugeot 306
When you change the diesel filter, it is recommended that you fill the container where you are lodged with a clean diesel to top, or that after mounting it and before starting it, you give the pear to the diesel. In this way you will completely eliminate air bubbles in the diesel circuit, preventing the car from stopping as soon as it is left due to lack of diesel. Once started, leave it a minute to idle or slightly accelerated (around 1200 1500 rpm) to finish purging alone.
To clean the turbo well, the good would be to disassemble the engine and clean the compressor turbine with diesel and a brush, ensuring that it does not between the lubrication tube or the exhaust turbine.
After having cleaned it, you blow it with compressed air and by the greased racor you put a few triggers with the oil and normal engine oil (to remove the diesel from the axis bearings).
You ride it and keep the engine over 1500 rpm for a minute, so that all the diesel that could have been on the escape side and in the admission snail is evaporated.
The intercooler and the air collector, you can submerge them for several hours in gasoline, solvent, diesel or water with detergent (motor cleaner) and find a brush where you can.
Eye with the causic soda because aluminum is eaten.
When you get it out of the "bath" you clarify it well with pressure water, and if you could wash it with a pressure water hydrolavator it would be the best way to remove all the oil from the interior, especially from the intercooler.
Notice, because something is noticeable, especially when you clean intercooler more than the turbo or collector, since it is where the air has the most restriction when it passes when it gets dirty.
Greetings and hopefully I don't give you much war!
13 years 4 months before #33085 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with Peugeot 306 TD
Good. I would ask about this old post, because I have a Peugeot 306 1.9 TD with the same problem and it is crazy.
When you start it goes well (well done some smoke) Xro the problem comes then when it starts to heat dugs, and the revolution needle gives small drops of revolutions.
If I leave Ralenti as soon as he started at 5 min or so smoks a lot and stays like not burning any cylinder.
I have cleaned the admission collector, EGR, and new diesel filter.
Could you repair the problem?
It would be of great help. Thank you very much for everything. A greeting
13 years 4 months before #33116 by manual-mecanica
You can have several things, a bad heater, out -of -point lip, bad adjustment and air intake in the diesel if after reviewing all this continues to fail you tell me
13 years 4 months before #33234 by manual-mecanica
The heater I have looked at them, and they are fine, I also change the diesel filter because it was wrong, and it is still the same, before the diesel inlet tube had bubbles but when I changed the filter it took off. I will see if the pump is badly regulated. The taques I think they are hydraulic, or it sounds like that I saw that in the autodata.
