Diagram or Manual of Sensors of Santa Fe 2004
14 years 11 months before #17378 by manual-mecanica
Diagram or Manual of Santa Fe Sensors 2004 Published by Manual-Mecanica
Please I need your help for a 2004 4 -cylinder Hyundai Santa Fe truck, I have problems with the sensors does not turn on your engine. Thanks anticipated
14 years 11 months before #17431 by manual-mecanica
Manual-Mecanica Response on the Re: Diagram or Sensors Manual of Santa Fe 2004
First it is the first thing you see that you are missing for it to start, if it is common (spark) or if it is fuel. Czech and warn
14 years 10 months before #17675 by manual-mecanica
Thanks Kikemec I tell you that I found the fault was a connection that went to the starting sensor one wire stuck to another and produced a short circuit for that reason did not start.
