Acceleration problem Daihatsu Applause
15 years 4 weeks before #17352 by manual-mecanica
Daihatsu Applause Acceleration Problem - Posted by manual-mecanica
Hello estimates I have a Daihatsu Applause year 98, which is stuck to the acceleration in 1500 to 2000 rpm, once I kicked the accelerator low, but then it goes up again
15 years 3 weeks before #17369 by manual-mecanica
Manual-mechanics' response on the topic Re: Daihatsu Applause acceleration problem
Check that you don't have any false air intakes; this is the main problem when vehicles are accelerating. If not, check the correct operation and clean the IAC valve and the throttle body.
15 years 3 weeks before #17370 by manual-mecanica
I forgot to check that no sensor is disconnected, especially the temperature sensor.
14 years 11 months before #18168 by manual-mecanica
Have you ever washed the engine? Something very similar happened to me with the accelerator; it was the acceleration mechanism that was lacking lubrication from the pressurized water. I used some grease or petroleum jelly, and it worked like a charm; I've never had that problem again.
Cheers
