My Citroen Zx does not advance with automatic box
15 years 1 month before #16309 by manual-mecanica
My citroen only walks back the changes forward do not take : Silly:
15 years 1 month before #16311 by manual-mecanica
Vicko, so you will have to check if it carries electro valves and there is some deteriorated or you will have to open change to change a molten package : Woohoo:
15 years 1 month before #16316 by manual-mecanica
They can be a lot of things, burn records body of valves, bad oil you will have to take it to check the most caused thing is that they are the discs or the body of valves.
15 years 1 month before #16324 by manual-mecanica
If the oil was wrong I would not go back, right? : Woohoo:
15 years 1 month before #16329 by manual-mecanica
Do not need the friend of the reverse electrovalve as it is the last one in the line, you have seen more easily, you have seen when the automatic boxes sound like they explode, something like the against explications is for a precion that is lost and that does so only forward not by back. From what I have seen I am not very expected in automatic box of it I do not like to repair hahaha,
