Toyota 4.5 liters and 24 valves (1FZ-FE)
15 years 2 months before #15462 by manual-mecanica
Toyota 4.5 liters and 24 valves (1FZ-FE) published by Manual-Mecanica
Good morning to the forista of this medium I have a dilemma to whom I can attend in my question I have the Land Cruiser Toyota truck year 2002 with the specified engine 1FZ-FE about information regarding that the truck would be more prudent in question, it escapes smoke at the time of being on but in a stop place I mean in a semaphore when starting escape from the escape of oil. To escape smoke, the truck has a mileage of 195000 km the doubt that it would be better to change gums of valves or make a clear engine and buy the original tires a good investment but the dilemma is not to spend powder in Zamuro
15 years 2 months before #15464 by manual-mecanica
Manual-Mecanica response on the Re: Toyota 4.5 liters and 24 valves (1FZ-FE)
Hello; In the first place, it is raising oil and what is essential is to change the valve seals and the oil from now on you decide whether to repair the engine? : Angry:
15 years 1 month before #15884 by manual-mecanica
Hello before, it would be good to check if you are using the oil specified by the manufacturer or the recommended ekivalent and what not suitable oils produce these failures
15 years 1 month before #15911 by manual-mecanica
Look usually and in the common case that smoke in Toyota engines only goes through valve seals, so I am from the idea that you change and now, now if you want to make an adjustment it is your thing, but I believe for what you say is just change the valve seals, well anyway you will have to take out the cylinder head, so you can see if you can see if the rings pass the rings. And you checked the lucky game.
15 years 1 month before #15921 by manual-mecanica
I agree with the Kike Company
