Engine heating
15 years 2 months before #15150 by manual-mecanica
Motor heating published by Manual-Mecanica
Greetings ...
my car is like and a half ago since I lost compression in 2 pistons, but I began to heat up and it was necessary It is activated, my car is a 92´ tsuru.
15 years 2 months before #15155 by manual-mecanica
Manual-Mecanica response on the Re: Motor heating
Hello friend, did you have controlled the thermostat to see if it works well? greetings. : Cheer:
15 years 2 months before #15165 by manual-mecanica
I don't understand why you say it heats up if the electros leave for half?
15 years 2 months before #15191 by manual-mecanica
What happens to you is that the cylinder head or some shirt of the piston is filtering compression bubbles the auxiliary water tank Look B)
15 years 2 months before #15194 by manual-mecanica
I agree with Friend Caicedo, and if I lost compression for two cylinders it is, I assume, for a problem in the cylinder head, perhaps caused by an overheating. I presume then that perhaps only the packaging is changed and that the cylinder head was not thoroughly checked. The safest thing is that you have to disassemble the cylinder head and rectify it.
