RENAULT 19 DISTRIBUTION CORREA INCREA
15 years 3 months before #13580 by manual-mecanica
RENAULT 19 DISTRIBUTION CORREA PUBLISHED BY MANUAL-MECANICA
Hello guys every so often, I enter the page the truth is very good and it is very helpful at this time I am looking for some manual or vien Some tutorial of this model will be very grateful greetings and endurance (mechanics manuals) b) :)
15 years 2 months before #13733 by manual-mecanica
Manual-Mecanica Response on the Re: Putting Renault Distribution Still 19
Hello: I have the same car and the distribution is quite simple. The strap is placed with piston 1 on PMS and the shifts of the balancing, the tapas have marks. Although you should not pay attention. While putting 1 in PMS and the 4 piston cams in balancing. I hope it serves you
15 years 2 months before #13750 by manual-mecanica
Manual-Mecanica Answer on the Re: Putting Renault distribution strap
Hello, how are you karma --- Look is doing how I am putting the engine. The theme is that the cold car does not start after giving and giving the start light and delayed a tooth of the belt and starts but when I want to leave it regulating it is as if Nazta did not reach the caburer, I leave as it comes with the marks of the factory point is working but in reling the revolution In unstable this in Nazta because Gas does not want to know anything my question is how the car brings electronic ignition module with a captor to the wolf with Avase by water temperature by which the only way of giving progress or delaying it is through the belt it will not be that the module itself is generating the problem in a saying that it is delayed and progresses by itself that only the same module fails. A module but it may happen that you are presenting a failure for the module like the one I describe and that is the defect as I test this module to know what is taken to three houses so that they regret and end up telling me that the devices they possess do not serve them to daggnstate the module Siemens of this carburetor car this Vien The engine also does not find defects in which you have any sucking air by the air that I have left is the electric part but I rebuild and I can't find anything weird I would like to know that you advise me
15 years 2 months before #13751 by manual-mecanica
I apologize with your:( cdmotor:) nick:)
15 years 2 months before #13755 by manual-mecanica
Hi: No problem x the nickname, if you have CNG to also review the theme of the emulator. The ignition I do not think it is x that it is fixed and foolish, (fool is always sparking, but it has an emulator must be chopped the UC (the computer) you would have to do it x a specialist in CNC. Mine is mod 93 and I have the same problem in gasoline, I had to use it with the server lying a little Ultrasound, and nothing.
