Change silentblock of the front trapezios
18 years 5 months before #1346 by manual-mecanica
Change Silentblock of the front trapezoids published by Manual-Mecanica
Hello everyone,
I am not a mechanic but I do the little things that I can as everyone supposed: wink:
in the last itv they threw me: EVIL: to have the silentblock of the uploaded front trapezios, and my question is whether to change them it is easy, that is, how I see that the shock absorber is in between if a pressing press is needed. Remaking the wheel,
thank you very much,
it would be for a 96 Ford Mondeo, although I suppose it will be for almost all the technique of changing them:? :
18 years 5 months before #1363 by manual-mecanica
Manual-Mecanica response on the Re: change Silentblock of the front trapezoids
There is really no claws to press the dock because you are not going to disassemble the shock absorber dock.
First, lift the car, remove the wheel and fit it with a blur or something that gives you security. Do not leave the car with the cat to remove the wheels !!!
Then, you have to release the stabilizer bar if you have it, it is a transverse bar that crosses the front axle from side to side. Be careful because it can be strength if the two wheels are not raised.
And finally you have to release the trapezis of the chassis to be able to change the tires.
What I have told you is a little above because the best thing is that you download the Mondeo manual even in English and see the illustrations.
It is not necessary to release transmissions or bruises or shock absorbers, or hose.
Anyway, if you have any colleague that Pilote on the subject asks for help and invite you to some Birras Jaaaj.
All the best.
