Problem on the clutch pedal.
15 years 6 months before #12876 by manual-mecanica
Manual-Mecanica response on the Re: Problem on the clutch pedal.
Probable problem with the clucht, recycles the clutch dish
15 years 1 month before #16098 by manual-mecanica
: Ohmy: Well apparently my friend is in doubt about whether to give it up, it will depend on the fact that you like to keep your vehicle so much, in the first it is better in my humble opinion of making a prventive maintenance and not one corrective, only that of talking about the clutch system the maintenance are of lubrication and adjustment and if possible in the vehicle of which you speak, in most of the cars it is corrective. snoring or buzzing when the clutch operates, it is without a place that you have a problem, now that consequences would bring, problems by putting changes, rech The general you change the press, disc and collar ...
thanks for your patience.
14 years 10 months before #18224 by manual-mecanica
What was always with your clutch problem was solved?
