TRANSMISSION PLATINA DO NOT ENTER SELLINGS
15 years 8 months before #12629 by manual-mecanica
TRANSMISSION PAINA NO VELACITIES PUBLISHED BY MANUAL-MANICA
Hello friends,
if someone can help me, I will appreciate it.
I am working on a 2005 plain that do not enter the speeds (only the 5th entered), lower the box and open it, everything looks normal, except that in the reversal selector you can wear out where the selector finger of the control enters.
The truth is that I have no experience with transmissions and Rife, but I feel that I already stood out why I have not had whether it works or not, and how the control of the change should be assembled.
Thank you.
15 years 8 months before #12649 by manual-mecanica
Manual-Mecanica Response on the Re: Transmission Platina does not enter speeds
Try putting the marches by hand if they all enter or none, may the failure be there, the selector is ran because the varillage did you check it right?
15 years 8 months before #12727 by manual-mecanica
Thank you Kikemec,
yes, I already tried to put the changes, also notice wear in the first -to -hairline, I think that is why the selector is saved.
Now, if I try to run the synchronizing cubes with their hand they feel very hard, but they are not died, could they be the axes of the forks?
Thanks and greetings.
15 years 8 months before #12988 by manual-mecanica
Send me your email and send you the manual of the box or link where you can lower it thick me that you want the manual in the title of the message ok?
15 years 8 months before #13034 by manual-mecanica
Manual-Mecanica response on the subject Help with transmission manual
Thanks Kikemec.
In fact, a mechanic that I just met already reviewed it and it was only the wear of the 1A/2a horquile where the command lever fits.
Anyway, thank you for your answers, and if you can like to support me with the box manual I would appreciate it very much, because I would help me more about the subject.
greetings.
