Renault Megane 1.4 16 V coils
14 years 8 months before #19746 by manual-mecanica
Manual-Mecanica Response on the Renault Megane 1.4 16 V topic
I have no idea but that it is a pijada I have no doubt. Take care of that engine is great
14 years 6 months before #21376 by manual-mecanica
Hello colleagues, the air intake is located at the Board of the Box of the Admission collector, it is a fairly large round joint, I put the joint of an oil filter and solve forever.
13 years 9 months before #31259 by manual-mecanica
Did you fix the idle? Greetings I am worse, it fails me, no if a coil or, for having stopped a couple of months. I think it goes in 3 cylinders sometimes. Paste pulls.
13 years 9 months before #31260 by manual-mecanica
If you solve it, disassemble the admission collector and the butterfly box, you will see 4 joints and in the butterfly a large round joint, look for one of an oil filter (that of a Ford Ranger is perfect) and you place it, the other joints are placed black silicone and holy hand.
If the pulls are cold, thephallo can be of the air intake, if the temperature does not matter, you have one or more bad coils, also the spark plugs, they have to be original.
13 years 9 months before #31282 by manual-mecanica
Thank you very much, for me that they were going to be the coils, because now after having stopped the car for some time, they have failed me. Before it was only slowdown, now it goes in three cylinders. I have already bought the spark plugs, so I will try those. I am going to see the coils see if I can take advantage of some, they are worth a paste.
Your response has been for many help.
