Renault Megane 1.4 16 V coils
18 years 4 months before #1237 by manual-mecanica
Renault Megane 1.4 16 V coils published by Manual-Mecanica
To many users of a megane 1.4 16v or 1.6 16v, we melt the coils every two by three, I would like to know if anyone knows where this problem comes from, or if it is a failure of the coils themselves. In any case, is there any definitive solution? Thank you. All the best.
18 years 4 months before #1241 by manual-mecanica
Manual-Mecanica Response on the Renault Megane 1.4 16 V topic
Could someone tell me why all the winters cold?
... I think so, and that is that the design of my body (with all my things inside) induces that the change of tepeature lowers the defenses and catachan! again cold.
That type of engine melts and always melt those blissful coils, it is not any failure of the car or motor, it is the design of the coils and the high performance that is subjected, some spark plugs that are already a little bad also make the coil found.
But this technical roll will already tell you megabeat
I usually ride bosh spark plugs and dense coils, but my son guarantees you that they last for life.
14 years 5 months before #19598 by manual-mecanica
Ola I have a megane coupe 1. of 99 and I am very moskeoo the relief oscillates muxisimo and disassemble the valve of the relief the cleaned and I follow iwal I believe that this eight happens a lot that problem you can help you can help.
14 years 5 months before #19743 by manual-mecanica
Greetings Tonisan I have a 1.4 of 2002 and the same thing happened to me. And since I amount to the Bosh coils I have no problems, the last one will wear about 500km I hope my comment helps you
14 years 5 months before #19744 by manual-mecanica
OLA MIGUEL KE TALT, you would know how to say my relia is not stable.
