Dodge Caravan 3.0 98
15 years 7 months before #12214 by manual-mecanica
Dodge Caravan 3.0 98 Published by Manual-Mecanica
Hello, well, I have a doubt what happens that I have a caravan 98 3.0 that has a failure that already brings me crazy what happens that when the climate is on the piece to pull And nothing else does it to me at that speed they tell me what the box or the speed sensor can be ... and pus I really look for him and I did not help him to the guien B)
15 years 7 months before #12234 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with Dodge Caravan 3.0 98
I believe that jaloneo can go through a current problem you want the alternator does not charge as deveria, the jaloneo to 45 can be a cash problem, if it is clear automatic. But it is extremely difficult for you to repair it are very complicated
15 years 7 months before #12243 by manual-mecanica
Hello friend, do not look that you see if it is the ternator because nothing but no PSA of 12.70 and if I turn the climate to 12.3 12.7 volt. But it fixes that when you turn on the climate em a piece to pull more and draw white smoke but it is as if it were steam is not oil and it is not gas or anticojlante ... and the failure already brings me crazy. But the failure just in piece is done more not table when I turn on the weather, AI if you know advise me thanks ;)
15 years 7 months before #12267 by manual-mecanica
Repair that alternator should be delivering 13.5 as a minimum.
15 years 7 months before #12286 by manual-mecanica
Greetings friend ... In my opinion you must have excessive resistance in the spark plug wires, I suggest replacing them, also verify the fuel pressure.
