Vitaminando a Célica
18 years 7 months before #1163 by manual-mecanica
Vitaminando a Célica published by Manual-Mecanica
Hello kids, I have a Célica del 98 (the bifaro) and that I bought from 2nd hand in case the flute sounded, already sounded. Now I have sponsor to run in territorial, I have everything mounted (air filters, gum wheels, escape remus, shock absorbers turned to Selex ... etc) but the truth that the car I have lightened it a lot and still weighs a lot, what I would like is that you told me if you can reprogram the switchboard and win about 15 or 20 horse or that another way I can win them, knowing that I run in Grupo N. Thank you. :lol:
18 years 7 months before #1164 by manual-mecanica
Manual-Mecanica Response on the Re: Vitaminando a Célica
I forget to say that it is atmospheric multiválvulas and 1800 cc
18 years 7 months before #1166 by manual-mecanica
On the website www.mecanicavirtual.org you have a section in the forum that talks about the preparation of competition engines.
Anyway, I tell you some things:
the power is equal to gasoline correctly per unit of time (second).
If you increase the gasoline that enters the engine and do not increase the admission air will drown. To get a better filling:
1st polishing the intake manifold with the help of a dremel, a sanding accountckilometers and a lot of patience will give you about 6 or 7 horses because the air will have less friction resistance within the admission tubes.
2º Lightest the inertia steering wheel by 10%and balance the crankshaft will increase the engine response, even more if you choose to put a ceramic clutch.
3º Rectify the cylinder head plane to achieve a superior compression ratio but look at first the current compression ratio so as not to pass because it can sting connecting rod.
4º Taking advantage that you have removed the cylinder head for this, replaces the current valve guides with other bronze that have much less friction, and cuts with the dremel the valve guide part that stands out inside the admission collector in the butt. (Only admission, if you cut the exhaust guide you can burn the valve)
5th Look to see if they have the cylinders, if they do not leave them as they are, and if they have rectify them and mounted pistons and segments overmed.
6th I don't know what kind of injection does the cyclical carry, but surely he carries catalyst, take it away.
The Lambda probe you will not be able to remove it unless it is centralty.
The air filter should be a Green Cotton or a KN for its lower resistance to the air passage.
Look to see if there are camshafts with the highest crossing of valves than the one you have because you get a filling and emptying of the cylinder with the latter although you will have to climb it slowly until 1100 rpm because if it does not fit and stops.
Everything that I have told you arises effect, some things are cheap and others not so much, but what is not dirégly related to a greater full of air to the cylinders is oriented to achieve a greater number of revolutions per minute, in any case the power is increased although risks are also taken into account and luck.
PD forgot to me at www.donspeed.com The competition catalog this year.
18 years 7 months before #1173 by manual-mecanica
Joer Collega are the fucking master. I will do everything you can say and tell you, thank you very much.
18 years 7 months before #1174 by manual-mecanica
Once I saw an entire encyclopedia written in a grain of rice and ......
fuck !!!!! Yes, if possible the impossible.
That engine that you propose Megabeat is for a race or for a temperate?
Aver, Aver, how many were able to read that encyclopedia, source of knowing ....
Tranki Megabeat, Tanki.
The first thing that a Neesuta soccer team to win is a good striker, hey your kapy, are you a good pilot?
Evenke would give a f40 to Matias Prat continued won Alonso with a clio.
What I tell here is only a reflection of this my mind, about the technical section,
pay attention to what Megabite says because it has told you just how maximum that can be taken to the four times of your engine, Auncke disagree a little in the final part of the escape. Brand, but to calculate what is the retention needs that escape to optimize the combustion camera because it does not work well nigun free escape motor.
I have also heard something about chroming the shirts if that cars will also take the admission collector with a spiral grat, such as the tubes of any firearm.
Also larger tires instead of 17 of 21 for example, for the development of a wheel return.
Also the development of your gearbox .....
the aerodynamics .....
in short .....
I keep my grain of rice grain.
Pd still keda so that explain little megabite.
