Seat Ibiza Year1989
15 years 9 months before #11198 by manual-mecanica
Seat Ibiza Year1989 Published by Manual-Mecanica
Hello: I have given me a Seat Ibiza of the year 89, it is very basic. With 900cc motor-the car has 50000 kms real. The case is that it usually starts me bièn, but when it rains or when there is a
lot Will the problem end?
Thanks in advance
15 years 9 months before #11199 by manual-mecanica
Manual-Mecanica Response on the Re: Seat Ibiza Year1989
Hello, I would start by changing the lid, of the Coin that is the cheapest even if it is scrapping to try, and if there are not the platinos.
I am not a mechanic but I have had cars of that time and something similar happened to me and changing the lid,
the problem was solved.
greetings
15 years 9 months before #11212 by manual-mecanica
It is precisely the cover that is wet, you can do two things to change it or try to cell it with a rubber or cilicone or fat joint or something like that and you will be fine.
15 years 9 months before #11422 by manual-mecanica
Good afternoon, to start checking the status of the pipette or platinum as you want to call them. Once proven, check the contacts of the Cover of the C, the state, if you think it does not look good, change the lid. On the other hand I would check the state of spark plugs and cables to rule out some defect. Finally, seal the lid well to rule out that you have some kind of humidity problem again. All the best
15 years 9 months before #11437 by manual-mecanica
Subject solved, indeed it seems that it was from the cover of the ofco, a small adjustment to the platinos and the paracence car that now starts the first one has been made. Thank you all those who have answered me, they have served me a lot of help.
