KIA SORENTO 2006 MOTOR MOTOR D4CB
15 years 7 months before #11068 by manual-mecanica
KIA SORENTO 2006 MOTOR D4CB Published by Manual-Mecanica
Hello friends: If I could help me I need to urgently need the repair manual of the KIA SORENTO 2006 Motor D4CB 2.5 CRDI, I have some problems of loss of fuel pressure, I already change the injectors, but the problem follows, I need to rule out some other elements that are related to the fuel system. I will thank you for your attention.
Thank you.
Simon.
15 years 7 months before #11274 by manual-mecanica
Manual-Mecanica Response on the Re: Kia Sorento Manual 2006 Motor D4CB
When a sorento has combustion problems, it is usually due to the detachment of the internal protective layer of the fuel tank, this was a problem that Kia solved from the 2005 models.
If you already got the manual you can pass it to me, thanks thanks
14 years 11 months before #16152 by manual-mecanica
Hi Simon, how did you solve the problem at the end ??? something similar is happening to me
, greetings,
14 years 11 months before #16153 by manual-mecanica
I have a 2006 and I made the tank clean, after that at 4 days it stopped and does not want to start, they are seeing that it is
14 years 11 months before #16186 by manual-mecanica
I have a 2004 Hyundai Starex with D4CB engine just like Sorrento 2.5 CRDI. I repaired because I had no compression after they made a cylinder head repair in another workshop and they could not start it, I have downloaded the divers, I have proven that there is a pressure of oil in the system, but when I put the chain of the camshafts, according to the marks of the chain; The engine is locked and does not rotate. Pressum that there is another way to synchronize, if someone can help me or if someone has the workshop manual of this engine I will thank.
