Purge Toyota Yaris refrigeration system
15 years 10 months before #11009 by manual-mecanica
Purge Toyota Yaris refrigeration system published by Manual-Mecanica
Hello.
I have changed the thermostat and water pump to a Toyota Yaris D4D of 04 and I am not able to purge the circuit. I can't find any pirchar. And it also does not have heating so it makes me attach that it has air. Someone has happened to him. I am desperate !!!!
Thank you
15 years 10 months before #11013 by manual-mecanica
Manual-Mecanica Response on the Re: Purge Toyota Yaris Refrigeration System
But they eliminated the heating normally there they bring the spurter, what amount of refrigerant you have put it more or less 5 liros, try to fill everything and leave it at minimum until the fan starts normally works after it starts twice you turn off the car you expect that it cools and complete the level, eye attentive to the temperature always, check on the aspiration collector to see if it has any.
15 years 10 months before #11014 by manual-mecanica
Eye depends on what type of radiator we carry and how many channels is the dough or hive, see if it has any thin hose that comes out of the suction collector, you can loosen and make the air out there until it comes out only water, test, always eye at temperature
15 years 10 months before #11031 by manual-mecanica
You have been walking without the radiator lid, two fan siclos and stuffed
11 years 9 months before #45181 by manual-mecanica
Manual-Mecanica Response on the topic Purge Toyota Yaris refrigeration system
Alfonso Good morning, I have read Tumproblema four years ago from your car. The same is happening to me after changing the bomb, I would like to know what the problem ended, thanks.
