My astra does not start
15 years 11 months before #10576 by manual-mecanica
Manual-Mecanica response on the Retra theme : my astra does not start
Something fast takes out the injector rail and gives a little march to see if gasoline pressure injects the gasoline is check with a manometro that tells you what a prection that Lalinea has if you have a Czech gasoline, the high voltage circuit and cyrhons of the computer of your car a bad earth a bad earth
15 years 11 months before #10590 by manual-mecanica
Hello, check at the Ohil gas entrance of your injection pump there is usually a filter type thimble which usually covers itself by probating a drop on your injectors. When you start the pump it is at rest at more speed or journey the plugging is greater preventing Ohil gas from reaching your injectors, I hope it is useful.
15 years 11 months before #10600 by manual-mecanica
A question your car has electronic accelerator?
15 years 11 months before #10659 by manual-mecanica
Hello
1-If you followed the tips contributed for this time, it must be working
2-if it is not so fix if the distribution strap is damaged
3-cmproba if the heater are working
4-if it does not work to think about looking for someone to analyze it with the computer.
I hope your beiculo works., With respect if I have an equal one not, my hobi is the mechanics and when I have time I repair vehicles in my workshop.
13 years 9 months before #30946 by manual-mecanica
Someone tells me how they solved it since I also have the same mess,
