I can't open the Fiat Siena-Palio manual
16 years 3 weeks before #8200 by manual-mecanica
I can't open the Fiat Siena-Palio manual published by Manual-Mecanica
I have downloaded the Fiat Sienay Palio manual but I decompress and I can't open it, does anyone know the problem of this manual?
16 years 3 weeks before #8213 By manual-workshop
Manual-workshop response on the Re: I can't open the Fiat Siena-Palio manual
The size of the file is 139,698,230 bytes check that it is correct, if not, it is removed the browser's cahe and try to download it again. If the size is correct, I indicate that the file decompresses with the Winrar and a file appears that must be recorded to CD with the Nero or a similar program.
16 years 3 weeks before #8215 by manual-mecanica
Manual-Mecanica Answer on the Re: I can't open the Fiat Siena-Palio manual
The download size is correct !!!! To decompress it I did it with the Winrar, but it gives me a tutorial and the Imagines reader will not have;) the ISO file.
The issue is that I know why I should record it to a CD? Garcias for your help and let's see what can be done!
The problem I have is in my Fiat Siena, I feel the vibration in the traction when I raise the revolutions for each speed change, a mechanic made me the change of the left triceta, but the problem I still have it, the balance of covers and the alignment lasts to me one day !! I am thinking of consultations that can be the rulee (bened) of the homocinetic or the same homocinetic or also clutch problems. Well if anyone knows this I thank you if you can help me;)
16 years 3 weeks before #8220 By manual-workshop
You have to record it in a CD because it is a CD image file although you also have the option to mount it as a virtual disc unit with the Nero Immonrive program or the Ultraiso program.
16 years 3 weeks before #8233 by manual-mecanica
Hello and good morning,
the same thing happens to me with the BMW R1200GS Multilenguage manual, but I have tried to record it with the Nero, in the option of CD Start Disc and it has not been recorded, at the end of the process, it gives me error.
Is there any tutorial how to do it step by step?
GREETINGS;);)
