Hello friends again asking for your great help
11 years 3 months before #46304 by manual-mecanica
Hello friends again asking for your great help published by Manual-Mecanica
Good I tell you that now I change packaging to the butts of a legacy ej22 which entered the workshop but with a valve failure which settled valves and bushings which I remain impeccable but now that I assemble everything again I have problems since the vehicle normally turns on but when accelerating it does not respond as if the TPS does not send the order to the computer which already tries to They go to the sensors and they are all right if they could help me I would appreciate what could give me that problem
11 years 3 months before #46306 by manual-mecanica
Manual-Mecanica Answer on the subject Hello friends again asking for your great help
The same must be made a "learning between the butterfly (TPS sensor) so that the ECU recognizes its position. Then this is not throwing any code for any sensor that you have been able to let yourself be disconnected and entered you in "emergency mode" which does not let you accelerate. Greetings!!
11 years 3 months before #46319 by manual-mecanica
Thank you friend if you could explain a little more about learning between the stop
11 years 3 months before #46324 by manual-mecanica
The learning of the TPS or reading between Topes, according to the brand or car model; Sometimes it is not necessary, but sometimes it is when connecting battery and giving contact, if it is motorized body of butterfly it is done by ECU itself, other times the accelerator must We will have to inform ourselves. Greetings!!
11 years 2 months before #46370 by manual-mecanica
Well, friend I tell you that I continue with the same problem now verifying everything I got another sub -rac Verify the spark plugs or sinches are bathed in fuel.
