Cinematic Analysis
12 years 6 months before #41203 by manual-mecanica
Cinematic Analysis Published by Manual-Mecanica
Friends I am tremendously overwhelmed, since in the university I was in charge of doing the film analysis of 2 engines one diesel and another Otto, the problem I have is that I have sought a lot in your forum, but I have not been able to find a manual that contains the value of the oscillating mass of the engines, for example the weight of the crankshaft, cranks, etc., if someone could help me I would be very grateful.
12 years 6 months before #41205 by manual-mecanica
Manual-Mecanica Response on the topic Cinematic Analysis
These data are different in each engine and depend on displacement, manufacturer, food system and more.
The manufacturer saves details like those because it does not want to be plagiarized. It depends on the more the displacement the more will be the counterweight of the crankshaft, the more the cylinder the crankshaft.
The displacement depends on diameter to the square x pi divided by 4 x the race (d2.pi: 4 x career = cylindrated) and that by the number of cylinders.
CV / horses or steam horses = A cylindrated x gasoline density 0.740 Ambient temperature (15º more or less) x 0.001 (is a coastal) x 85 % which is volumetric yield, all divided by 14.7 (another coastal). Note: If it were Gas-Oil 78%volumetric yield, the diesel engine has less. [CX 0.740 x 0.001 x 85%: 14.7 = CV] X The number of pistons/cylinders.
We also have the stoichiometric mixture 14.7 grams of air to 1 gram of gasoline and in 14.5 air to 1 air of diesel. The greater the load greater displacement except the resistance per rubbing, except the compression resistance. density of the lubricant and then you get the television telling you that if you have the wheels with little air it spends more fuel hehehe.
I stop giving me the joda hehehe (of formulas) in Yotube there are videos of the functioning of what you are looking for in 3D animation and with Spanish explication.
12 years 6 months before #41208 by manual-mecanica
Thank you friend, operation of an engine, formulas, chemical thermal analysis, I have it clear; My problem is that I have not been able to find a manual, no matter what model or manufacturer the engine is, which contains the specific data of the oscillating mass (connecting rod+piston+crankshaft+steering wheel) since I need it to perform some calculations, such as the torque product of the dough.
Thanks anyway;)
