How is Athleon diagnosis
12 years 11 months before #38823 by manual-mecanica
How is the Athleon diagnosis published by Manual-Mecanica
Good, I have two Nissan Athleon trucks and the diagnosis is made by bridging in an eight -pin plug that carries on the right side of the dashboard but I do not know the puncture process or the fault codes, someone can help me. Thanks in advance. :(
12 years 10 months before #38913 by manual-mecanica
Manual-Mecanica response on the subject as the Athleon diagnosis is made
Hello, I suppose you talk about an Athleon with the B4-40TI/ B60TI engine, if so the connector you are talking about is not that of eight pins but that of six, (the other is for the ABS or to reprogram the picture, now I do not remember well). Attach a PDF file where you will see how to make the diagnosis. Remember, very important, to read the code first give contact and then make the bridge and to delete it first to make the bridge and then give contact.
12 years 10 months before #38914 by manual-mecanica
Wow! I see that you can't upload pdf files, I will try with another format. Greetings
