Much black smoke Mazda BT 50 2008 TD
13 years 1 week before - 13 years 1 week before #37958 by manual-mecanica
Much black smoke Mazda BT 50 2008 TD published by Manual-Mecanica
Hello everyone I have a Pik-Up Mazda BT 50 2008 TD, the engine is 12 valves, (I comment on the engine because I have seen that there are different motorizations of that same year.
fact is that it is done a lot And thank you very much for the answers
Latest edition: 13 years 1 week before by .
13 years 6 days before #37980 by manual-mecanica
Manual-Mecanica Answer on the subject Much Mazda Bt 50 2008 TD
It may be a problem in the temperature sensor, check its correct operation.
(I spend in a Toyota Cammon Rail)
luck, and I hope someone can help you.
13 years 6 days before - 13 years 6 days before #37981 by manual-mecanica
Thank you Guillermo, to see if I find out where the sensor is, anyway I have changed filters, oil, I have cleaned the engine with an additive, I have put a clean injectors, already improved a lot, almost not made that black Humazo (it was the air filter), it only does when I accelerate a lot. I don't know if I do not do it because I have not started it cold, tomorrow I will see, maybe with a little lucky luck.
Latest edition: 13 years 6 days before by .
13 years 6 days before #37982 by manual-mecanica
By smoke theme also testing the exhaust tube since in this Ollin accumulates it is simple to make it very much that improves
13 years 4 days before #38061 by manual-mecanica
Well, it seems that something has improved with what I did to him, he hardly varies the release, just a pelin, so I will continue to miss the additive to the diesel.
I have also cleaned the admission collector, and the escape ... They had carbonilla to bore, and now I will see if the EGR valve cleaned, but I don't know exactly what it is, could anyone tell me?
