Eclipse GST 98 - Normal sensors
13 years 2 months before #37764 by manual-mecanica
Eclipse GST 98 - Normal Sensor Values ​​Published by manual-mecanica
Good morning, I have a 1998 Mitsubishi Eclipse GST.
I recently bought a scanner to read the ECU values. The device works fine, but I need to know the correct values ​​for each sensor on this car so I can compare them with the information the scanner provides.
Thanks in advance for your help.
13 years 2 months before #37778 by manual-mecanica
Manual-mechanical response on the topic Eclipse GST 98 - Normal sensor values
- The temperature sensor varies according to the engine temperature.
- The TPS sensor values ​​should vary between 0.5 and 1.1v with the throttle closed, up to a value of approximately 4.8v with the throttle open; this is tested with different acceleration states.
- the oxygen sensor should vary constantly within ranges of 0.350 to 0.750v.
- The MAF should vary between 1.8v and 2.9v at idle and it should vary when accelerating.
Here's an explanatory video... Good luck.
13 years 2 months before #37788 by manual-mecanica
Thanks so much for your help, Guillermo!
I have one more question:
My car had a TPS sensor error. I cleared the error from the log and it hasn't come back since. What I don't know is if the computer automatically resets to the correct values ​​after the error or if they need to be manually adjusted. There are no errors now, but I think it's running rich because after a 1600 km trip there was soot on the bumper, which obviously came from the exhaust.
Thanks again for your help.
13 years 2 months before #37790 by manual-mecanica
What error code did it have?
If you used the scanner, it should have given you a fault code; that's where we need to start.
Tell us what it is, and we'll see what the problem might be and how to fix it.
Regards
13 years 2 months before #37812 by manual-mecanica
The error code was P0120, which, according to the description I found on the following page: www.troublecodes.net/mitsu/ , means: Throttle Position circuit. The thing is, it hasn't reappeared, and I don't know if the excessive fuel consumption I mentioned in the other message could be related to that error or something else.
