CHANGE CORREA DISTRIBUTION PEUGOOT 307 GASOLINA1.6
13 years 8 months before #31442 by manual-mecanica
My Peugeot 307 1.6 gasoline has 83,000km and I have never changed the distribution strap; The car is 10 years old: what kilometers should the distribution kit replace?
13 years 7 months before #31636 by manual-mecanica
Actually because of my experience, almost all distribution straps are changed between 60,000 and 80,000 km, when more, it depends a lot on the manufacturer, it seems to me that you are already "peasadito", also changes the tensioners, it is usually recommended
greetings
13 years 7 months before #31638 by manual-mecanica
Hi:
There are for my experience the normal thing is to change it between 80,000km and 100,000km. Everything goes in reference as the partner told the manufacturer previously and it is more there are some K come for more km .. If you are going to replace it I would recommend the following:
complete distribution kit. (Rollers, tensioner, Correa
Air strap
alternator
water pump
etc ... It is something more expensive yes but since the car ready for quite a while and without problems ...
do not cry in the antifreeze K is an essential part for a good refrigeration and with a good quality the engine shows it as well as the water pump ..
greetings
13 years 7 months before #31665 by manual-mecanica
thank you so much
13 years 7 months before #31666 by manual-mecanica
You still have time to change it I have a Peugeot 306 and they are changed to the 90,000 and it has 275000 and without problem changing the tensioners of the belt also for what they cost is not worth it to play it
