EGR
14 years 7 months before #21545 by manual-mecanica
EGR published by Manual-Mecanica
Hello friends I have a Kiron of 2006 I would like to know where the EGR valve of this car is located to cancel it.
Greetings to the whole forum
thanks.
14 years 7 months before #21593 by manual-mecanica
Manual-Mecanica Response on the Re: EGR
It is not advisable to suspend the EGR, it is arranged to fulfill an import function.
The best way to look for it is to observe, the communication by hoses from the admission multiple and the exhaust multiple in the middle of the two is the EGR.
Chao
14 years 7 months before #21594 by manual-mecanica
Before saying eliminating it, you should read a bit which is the function of this valve there are many people who eliminate it but if your car is injection you would always have a fault light and the switchboard could modify you the parameters of the car, inform yourself before.-
It is usually a valve that is connected between the multiple of admission and in escape .-
14 years 6 months before #21637 by manual-mecanica
The function of this element I know, what I want is to clean it the car has a hard time answering.
14 years 6 months before #21644 by manual-mecanica
Greetings, there are two cases that the EGR produces fault, one of them is when it is open, the exhaust gases pass to the admission and produce slow response, apart from that when you light it in cold it is difficult to keep the minimum, the other fault is that it obstructs or closed the EGR, then the exhaust gases increase its temperature, some engines begin to reheat for the same. For cleaning, many use the same acceleration bodies cleaners, since it accumulates is Hollin and Carbon. Luck.
