Pesquise no MDM
Boletim
Escort 97 Problema de freio de mão
  • Autor do assunto
  • Pensionista fresco
Avançar
17 anos 1 mês antes #4994 por Manual-Mecanica
Escort 97 Handbrake Problem publicado pela Manual-Mecanica
Hello everyone, I have problems with the hand brake of a Ford Escort Model 97, it has a four -wheel disc brake, the problem is that when changing the rear pads the handbrake no longer worked (it is no longer activated) I had already spent it, and after much activate the hand brake lever, it was beginning to grab again, but as I can do so that the problem does not happen again in another change in another change in another change in another change
  • Autor do assunto
Avançar
17 anos 1 mês antes #5025 por Manual-Mecanica
Resposta Manual-Mecanica no RE: Problema com Escort Handbrake 97
Eu acho que quando os comprimidos mudam, você não coloca o cabo na mordaça.
