Pesquise no MDM
Boletim
Nissan Terrano Truck Problem YD25
  • Autor do assunto
  • Pensionista fresco
Avançar
11 anos 5 meses antes #46810 por Manual-Mecanica
Nissan Terrano Truck Problem YD25 Publicado pela Manual-Mecanica
Hello, if they could help me with this problem ... the engine costs to start and when it does not keep the slowdown, I made a scanner what I threw Crakshaft sensor out of the range I got a sensor and I changed what did not result ... Review the voltage and everything ok ...hand more tests change the sensor of the cams The camshaft I forgot to connect it and I started the engine and this party without any problem and without check keeps the idle accelerates and does not boot Fume, então conecte -o e o motor parou ... Eu poderia até me guiar mais ou menos qual pode ser o fracasso?
  • Autor do assunto
Avançar
11 anos 3 meses antes #47229 por Manual-Mecanica
Resposta Manual-Mecanica sobre o problema com Nissan Terrano Truck YD25 Motor
Seeing that my question has several visits I suppose that more than one may have the same problem ... I comment that I would find a forum that helped me with the problem what came out was problem with the distribution what made me think of how I could happen if I had chains and what I found is that, indeed a chain (camshaft) was a little more stretched compared to another which changed the 2 tensioners and the 2 chains for safety and the vehicle Problem ... The fault was produced by that small more long of the chain which desencorajou o motor e me jogou sensor de virabrequim fora do alcance ... Compartê -lo esperando que outra pessoa o sirva ... : Rir:
