Pesquise no MDM
Boletim
Lanos Time Belt 1999 Motor 1600
  • Autor do assunto
  • Pensionista fresco
Avançar
13 anos 9 meses antes #30615 por Manual-Mecanica
Lanos Time Belt 1999 Motor 1600 publicado pela Manual-Mecanica
Como o Motor 1600 Daewo Lanos 1999 é alterado
  • Autor do assunto
Avançar
13 anos 9 meses antes #30791 por Manual-Mecanica
Resposta Manual-Mecanica no Re: Lanos Time Stroke 1999 Motor 1600
A advice, take it to a mechanic, because if you have DH you have to take to the hydraulic pump, the motor taco, the auxiliary straps, etc., then you have to put all the brands coinciding, the crankshaft, the camshaft and if not badly say with the water pump you give the tension to the belt, it is a subject, if you look bad or you can break something or you will take the engine. Para a prática mecânica e Bueno, que a mecânica pratica com Oignen Cerses !!!!!! Ajajajaja no topo nós cobramos !!!!
