Pesquise no MDM
Boletim
A4 2.0L Jetta Oil Bomba
  • Autor do assunto
  • Pensionista fresco
Avançar
12 anos 10 meses antes #39173 por Manual-Mecanica
Jetta A4 2.0L Oil Pump Publicado pela Manual-Mecanica
As for the forum, I am that the sadness takes me, my _jetta a4 of 2000 2.0l, is automatic, started with a detail in the box, did not pass a change, that the fault appeared after service to the box, my mechanic told me that it was the body of valves and I fix it, but the fault did not correct it because it makes it only sometimes and more when I want to accelerate to rise, then I want to accelerate it. Ele me disse que não tinha códigos de falha no CJ4 e que ele teve que trazer o carro quando apresentou a culpa.
Here the good starts, take it to the road and if I present the fault but also turned on the acite light on the board, and I had to stop to check, I thought I could miss acite but no, then I took the car to the mechanic again and told me that he had Sure is the oil pump but I want to know what they think of this or it will be more serious ....
I await your response friends
and how bad it is dry, because I spend money fixing the faults of the box .. so you will know how I feel ...
Se alguém puder me aconselhar, gostaria de tentar mudá -lo por não ser tão complicado.
Eu não sou um mecânico, mas tenho númeras.
  • Autor do assunto
Avançar
12 anos 10 meses antes #39223 por Manual-Mecanica
Resposta Manual-Mecanica sobre o tópico Jetta A4 2.0L Bomba de óleo
Olá, aqui neste site você pode ver o Manual Mecânico: Manual Mecânico e Workshop Volkswagen Jetta e Golf A4 1999-2000 GTI VR6
