Hyunday H100 MOTEUR 2,4 GASOLINE 2005
13 ans 10 mois avant #31108 par manuelle mécanica
Hyunday H100 Motor 2.4 Gasoline 2005 Publié par Manual-mécanica
Hello my problem is this:
I have an H100 that since I bought it fails when starting
and even at its optimal temperature it fails to the start as if it were carburetor I have to keep it accelerated a little for 1 min later it is removed and it is working well as I repeat this procedure I do it even with the hot engine I need its help to find the fault since my scanner does not read this engine
10 ans 10 mois avant #48596 par manuelle mécanica
Réponse manuelle de mécanica sur le moteur Hyunday H100 2.4 Gasoline 2005
Nettoyez votre corps d'accélération et votre valve IAC
