FLOW IN THE INJECTORS MOTORS TDCI HDI 1.4
14 years 11 months before #17461 by manual-mecanica
FLOW IN THE INJECTORS TDCI HDI 1.4 MOTORS PUBLISHED BY MANUAL-MANICA
Well that: that these engines have this failure. With the kilometers the incentors begin to escape. They make a noise similar to a sprinkler of the PSS PSS, PSSS, something like that. Inside the vehicle, gases and their bad smell enter, especially when stopping with the engine running and if you put the fan or air conditioning you already directly poison you. In the workshop you put new copper joints where they settle and the return tubes, etc., but soon are the same, at least mine. If anyone knows valid solution, please share it here in the forum. Greetings. Ah !!! I forgot these engines by Ford Fiesta and Fusion the Peugeot 206 207 Citroen C3 C2 Mazda 2 and some more I do not remember.
14 years 10 months before #18241 by manual-mecanica
Manual-Mecanica Response on the Re: Fuga in the TDCI HDI 1.4 engines.
Hello, you would have to make sure if there is any technical or technical circular modification in the official dealership even if the vehicle is out of charge or attracts customer attention to Ford or PSA Group
14 years 10 months before #18454 by manual-mecanica
You have to review the seat seat where the washers go with a strawberry and put the new aranelas.
14 years 10 months before #18489 by manual-mecanica
Mmm Fuga in the injectors is not because of the HDI system if the injector drills your piston,
see if you are changing the theme of the joints where the return of gases goes means something you are having too much vent o Hydraulic depends on the wear, but directly to rectify and set of piston and rings
as you know the perfect combustion there is nothing more than in the theory that is why the issue of the return of venting of bad gases burned, these returns are common are always a
littleu Another thing the catalyster if it has to open it to look at it this walking and resigns all the gases, the same when they look they will realize if
there
is
Joid Those gases maybe this punctured
gives a lot of compliance with that because the truth can be harmful to your health and for your pocket
greetings I hope to be more help
I will try to follow you a little the post Aver if I can help you more
