SYMPTOMS: RUNNY IDLE, LOSS
OF POWER
, ENGINE SHAKES AT IDLE.
PROBLEM: COIL.
SOLUTION: COIL REPLACEMENT
. HOW TO DIAGNOSE: To find out which of the four coils is bad and replace it, perform the following test: With the engine running, disconnect coil number 1 (the first one counting from the transmission towards the distributor). Disconnect the plug. If the engine stops, it is in good condition. Then move on to the next coil. If you disconnect one and the vehicle does not stop, that is the problem. These coils are usually replaced in pairs, but if you don't want to do that and only want to replace one, you must find the two coils that, when disconnected while the car is running, do not cause the vehicle to stop. Remove one of these and put it in the place of the ones that caused the vehicle to stop, and do the test again. The vehicle should not stop when disconnected. Stop, replace, and that's it.
