V8 Ford 302 engine in Datsun Mod. 1973 ??? X0
15 years 2 months before #16646 by manual-mecanica
V8 Ford 302 engine in Datsun Mod. 1973 ??? X0 Published by Manual-Mecanica
Hello again from asking haha ​​good the question is:
If when putting a V8 Ford 302 engine, a 1973 A Datsun, I have to reinforce or change pieces of the suspension to support the weight ????????
thanks and see you later take care
15 years 1 month before #17209 by manual-mecanica
Manual-Mecanica Response on the Re: V8 Ford 302 Motor in Datsun Mod. 1973 ??? X0
It depends on so many vibrations cause the engine, the best thing in this case is to make the change and then provise, if the engine is oil and the vehicle was defeating, the vibrations if they affect, because there are many more and you have to reinforce the motor supports the only problem is that the body sooner or early sedera.
15 years 1 month before #17251 by manual-mecanica
Give him the car then tell you the same where Nesecitas reinforce it and I do the same but on the contrary smaller engines in larger cars, a 22R in a Toyota V6 ... but it is a logic question ... Good luck
14 years 2 months before #26407 by manual-mecanica
You would have to reinforce the entire suspension because the torque and the weight of the engine are too much for that type of body
with this leads you to modify to the braking system and you would get the broth more expensive than the albondigas.
14 years 2 months before #26409 by manual-mecanica
To start that cuckoo I do not think that you do and if you do they will have to modify the bridge that joins the trays and how it is high sure the hood will not close
