VW Jetta 2000 hydraulic direction bomb
15 years 9 months before #9978 by manual-mecanica
Hydraulic DIRECT PUMP VW Jetta 2000 Published by Manual-Mecanica
Thank you ... I have a sound ... in the pump of the hiidraulic direction in a VW Jetta of 2000 VR6 .... The problem was that I had a license for the rack and pinion (sorry we say it is said in Spanish) ... well.. I still have a sound like a pump without liquid ... This tense bubbles ne the liquid container ... when the car is preceded ... and when the car accelerates ... it sounds a stronger poko ... in a minimum not much ... it is heard .... nose if it is p [or that the system ties the system or something I am doing badly ... please please help me solve this problem ... Thank you before hand ...
15 years 9 months before #9982 by manual-mecanica
Manual-Mecanica Response On the Re: Hyd DIRECTURE PUMP VW Jetta 2000
If the pump is not to have any noise, now the sound may not be of the pump but of another component that is dragged by the same belt, now the way of loading this system is with the engine running you add the oil and you turn the steering wheel to the two stops like this, take the air from the system, it takes a while about 15 minutes or so.
15 years 9 months before #10042 by manual-mecanica
Hello .... the bomb is not new ... I was used to put it .. I bought it in those places where there are many used and thrown cars ... well ... I may have touched a bad pump.
15 years 9 months before #10168 by manual-mecanica
That pump needs a special VW dede liquid. It is possible that the bomb you bought was damaged ... it usually happens or failing that the circuit is poorly purged.
Raise the front wheels and with the motor off the direction turns several times, then with the engine you have the same the same several times the car already stops the address with engine on several times and should be solved ... always check the fluid level so that it does not between air to the circuit .. I hope it helps you
15 years 9 months before #10179 by manual-mecanica
Hey Junior .... THANKS..PORR YOUR COLLABORATION .... I will have to change the bomb I denied I believe yop ... to get out of doubt ... because what you say about turning for one side and the other, I did several times ... and I will give up what you tell me ... with other bomb ... Thank you ... we are in contact.
