CORDOBA 2002
18 years 11 months before #995 by manual-mecanica
cordoba 2002 Published by manual-mecanica
The EPC Light is turned on on the board of electrical problem on the accelerator pedal, but nevertheless the car is luxurious ... it has something fly, does anyone know that it can be ??
18 years 10 months ago #1009 by manual-mecanica
Manual-mechanics' response on the topic Re: Cordoba 2002
From the limited information, it seems to be a faulty circuit,
either in the wiring, the throttle position switch/accelerator pedal, or the engine control module.
I don't know if this will help much.
If you had access to a diagnostic tool, or with a little know-how with a laptop, you could probably fix it, but of course, then you wouldn't have asked, hahaha.
Cheers!
