Causes of lack of compression in the piston
16 years 2 weeks before #9906 by manual-mecanica
Causes of lack of compression in the piston published by Manual-Mecanica
Hello everyone.
I would like to know what are the causes for a piston to normally lose the compression.
Is it true that vehicle overheating can cause compression loss in the piston?
Thanks and greetings !!
16 years 2 weeks before #9910 by manual-mecanica
Manual-Mecanica Response on the Re: Causes of lack of compression in the piston
The causes of the lack of comprehensive in a cylinder are diverse, you can be, by rings, by oval cylinders, by crooked valves, by valves or by the croad packing.
If it is true that an engine overheating can affect the compression since it can produce a deterioration of the cylinder head packaging, or deformity of it, as well as a deformation of the cylinder and clogging or routing of rings.
