With motor bond problems
16 years 2 months before #9842 by manual-mecanica
With motor or engine bone problems published by Manual-Mecanica
The problem of the osilacines can have the carbulator the engine, or the foul, or a lot of fuel, when it is left without fuel
16 years 2 months before #9964 by manual-mecanica
Manual-Mecanica response on the Re: with motor bear problems
Hello, if you still do not solve your problem, check spark plugs, if the spark plugs are black is problems with gasoline, light it at night or in a dark place in case there are current jumps where it is, Czech filters, hoses both as a gasoline line and those of emptiness, if you are not afraid of discharge of the spark plug wires. Be strong and bluish. You will also realize if the fault improves or worsens. This is a somewhat archaic test but it is lucky. : UNSURE:
