VW Combi 92
16 years 3 weeks before #9797 by manual-mecanica
VW Combi 92 Published by Manual-Mecanica
Hala my problem consists among other things in which, I have the truck fallen to the left, in the front.
And in the electric part the life, nor the turns work.
For the mechanical part, it has no strength, but recovers a bit when used with the primer put all the time.
thank you.
16 years 3 weeks before #9806 by manual-mecanica
Manual-Mecanica Answer on the Re: VW Combi 92
And what is your question? What do you want to know? If this fallen spirals, if the turns or the Czech fuses and relays do not work, if they are ok checks the ampoules and that they reach them current. The force is already motor, a simple adjustment and already, perform a basic refinement to see.
16 years 3 weeks before #9815 by manual-mecanica
Very well thank you
15 years 11 months before #10302 by manual-mecanica
Both the front and rear suspension in a VW OMPI, have torsion bars. In the front suspension the bars are hidden in the front suspension box. It is likely that in your combi one of them has been broken and that is why it is fallen to that side.
Check the fuses for the operation of the indicator lamps and the crossing indicators (turns), also prove their bulbs.
Make an engine tuning that includes:
-Chambio of spark plug, adjust between iron to 0.60 mm
-Revision/change of the electrical components of the ignition low and high voltage side
spark plug wires, distributor cover, distributor rotor, platinos and condenser or collection coil and electronic ignition module according to the case. Platinos adjust to 0.40 to 0.50 mm. 5th BTDC Ignition adjustment
-Automated admission and escape valves, 0.15 mm.
Carburetor washing and adjustment, gasoline filter change and carburetor air filter.
I hope I have helped
