The engine is failing
16 years 3 weeks before #9785 by manual-mecanica
The engine is failing by manual-mecanica
Hello, I have a consultation the engine fails, in cold, it is as if it worked in three cylinders, although, it starts without problems in the morning.
During the brand already hot, sometimes it is also to be failed but when accelerating, but then it accommodates and does not fuck more that can be
: UNSURE:
16 years 3 weeks before #9787 by manual-mecanica
Manual-Mecanica response on the Re: the engine is failing
Good Daniel, I tell you that to start it would be good to know what kind of vehicle do you have to try to help you, carbure or injected? 4, 6, 8 cylinders, diesel? gasoline ? Maybe brand ...
usually this problem you have refers to the cylinder lid joint, so hot matches, but it is necessary at least to know what we are dealing with, a more specific touch ..: Woohoo: A hug
16 years 3 weeks before #9796 by manual-mecanica
Hello, how are you, thanks for answering my question.
I tell you that it is a Ford Orion to Carburetor, but it works at CNC. 4 cylinders.
For now, in what is using it every time you see more and therefore it takes longer to recover the failures.
thank you.
16 years 2 weeks before #9826 by manual-mecanica
Hello, how are you telling you that you start checking the spark plugs that especially when it is gas is even more delicate.
16 years 1 week before #9920 by manual-mecanica
Thank you, look check them and are dry but of a color like oxidized, all cylinders work, but not all the same.
a hug
