T-Belt Toyota indicator
16 years 3 weeks before #9754 by manual-mecanica
indicator T-Belt Toyota published by Manual-Mecanica
Hi, I'm Daniel! Would you need, if anyone knows how the T-Belt light of a Toyota Hi Lux 2.5 of 2006 is turned off or reset? Of course, thank you very much !!!!!!!
16 years 3 weeks before #9758 by manual-mecanica
Manual-Mecanica Answer on the Re: T-Belt Toyota Indicator
In the previous models you had to get the klm -account marker and give a switch that had behind, in this model I do not know if it is the same, what is usually more likely to have to plug it in a diagnosis, a greeting.
16 years 2 weeks before #9849 by manual-mecanica
I hope it serves you luck : Silly:
16 years 2 weeks before #9856 by manual-mecanica
Hello, change your distribution strap, in the case that the Echo is looking for the reset button, mmmmmmm 2.5 Which engine is it?
16 years 2 weeks before #9890 by manual-mecanica
Hello, thanks for your help, the belt already replaces it. The engine is the 1KD FTV with electronic injection, D4D Tegnology and there is no such button on the board
