PEUGEOT 406 TD YEAR 98 PROBLEM COM THE START
16 years 3 weeks before #9735 by manual-mecanica
YEAR COMB PROBLEM
Hello, I have a 406 TD 90CV year 98 and the problem I have is that when I go, the needle of the tapervolutions has stopped, it starts and the engine sounds fatal, the air conditioning does not work, nor the fans of the engine, I stop it and I start again and it goes perfect, but it is increasingly often more often. If this happened to someone and could help me, I would appreciate it very much. Thank you all anyway
16 years 3 weeks before #9741 by manual-mecanica
Manual-Mecanica Response on the Re: Peugeot 406 TD year 98 problem with start
I had a similar problem with a 206 and the battery was the cause, Chekala does not lose anything you want is the same failure
