Ford Ranger Electrical System 93
16 years 1 month before #9659 by manual-mecanica
Ford Ranger 93 Electrical System published by Manual-Mecanica
Hello again, I have Ford Ranger 93, ( I just bought it ), which does not work for the lights of R / L, check the fuses and all are fine, I would like a small advice.
I have knowledge in electronics just in case
, greetings from Honduras.B)
16 years 1 month before #9662 by manual-mecanica
Manual-Mecanica Response on the Re: Electrical System of Ford Ranger 93
If the ampoules are in good condition, check the flash, which is the most caused thing that fails
16 years 1 month before #9675 by manual-mecanica
The ampoules check and work, they are in good condition, I only found a flash that works with unemployment lights, but there is only one, is it the same for both systems or does another lack?
Thanks for your collaboration.
16 years 1 month before #9676 by manual-mecanica
It is the same in your case if it is in good Czech condition, the telecoming-
16 years 1 month before #9682 by manual-mecanica
The relay of the interminters easily differs from other relays, since the intermittency is a relay with three terminals.
Greetings.
