Ford Ranger Electrical System 93
15 years 10 months before #9659 by manual-mecanica
Ford Ranger 93 Electrical System published by Manual-Mecanica
Hello again, I have Ford Ranger 93, ( I just bought it ), which does not work for the lights of R / L, check the fuses and all are fine, I would like a small advice.
I have knowledge in electronics just in case
, greetings from Honduras.B)
15 years 10 months before #9662 by manual-mecanica
Manual-Mecanica Response on the Re: Electrical System of Ford Ranger 93
If the ampoules are in good condition, check the flash, which is the most caused thing that fails
15 years 10 months before #9675 by manual-mecanica
The ampoules check and work, they are in good condition, I only found a flash that works with unemployment lights, but there is only one, is it the same for both systems or does another lack?
Thanks for your collaboration.
15 years 10 months before #9676 by manual-mecanica
It is the same in your case if it is in good Czech condition, the telecoming-
15 years 10 months before #9682 by manual-mecanica
The relay of the interminters easily differs from other relays, since the intermittency is a relay with three terminals.
Greetings.
