Alfa Romeo 155 temperature I think it's very high
16 years 1 month before #9595 by manual-mecanica
I acquired an Alfa Romeo 155 TS, from 1995, my question is whether it is normal for the engine to always work at 90 degrees since, no matter how much the radiator refrigerant fluid changes and sending this clean, continues with this operating temperature, here where the temperatures are high are almost not low from 30 degrees, if anyone knows anything about it, I appreciate it, thank you!
16 years 1 month before #9596 by manual-mecanica
Hello friend, that temperature is fine for that more model that you tell me that there are very high temperatures, anyway check the thermostat and if you see it doubtful change it, it is not a face face and you make sure you have no future problems, look if the electrventilator couples correctly, I hope it helps you, a hug.
16 years 1 month before #9597 by manual-mecanica
Manual-Mecanica response on the Re: Re: Alfa Romeo 155 I think it is very high
Ok, thanks for the aid, then it is normal 90 degrees in operation, the fan already changed it to a new one, and also changes the bulb that activates the electro the radiator cooling fan, which goes down at the water outlet of the radiator to the engine to the engine
16 years 1 month before #9599 by manual-mecanica
It is the normal operation temperature of almost all cars by the design of the meter is practically halfway.
