Seat Marbella
16 years 1 month before #9522 by manual-mecanica
Seat Marbella published by Manual-Mecanica
I have 1994 Seat Marbella, it is of electric teaching, it is going well for Arranqe, by road, it does not give pulls, I do not stop, but the light of breakdown when I am circulating does not stop whistling. HBER if someone can give me any track
16 years 1 month before #9525 by manual-mecanica
Manual-Mecanica Response on the Re: Seat Marbella
Check warning light is on or flically flicker? : Silly:
16 years 1 month before #9529 by manual-mecanica
The light is always whistling, but as I commented to the car I not notice anything when circulating with the : UNSURE:
16 years 1 month before #9531 by manual-mecanica
Hello, how do you know the fault can be in a sensor like air temperature or atmoferic precion you need to check with the ECU of your mobile: D
greetings
16 years 1 month before #9533 by manual-mecanica
Hello, verify whether electronic carburetor, but the air shooter was manual, it could happen that the cable did not return completely to its resting position, if not, you will have to check the unit to verify possible failures as indicated by a partner in another report.
I hope helps greetings from Tenerife
