Nissan Altima 93 temperature
16 years 1 month before #9478 by manual-mecanica
Nissan Altima 93 Temperature published by Manual-Mecanica
I have problems with the temperature of my car since it is heating is passed 1/4 more than half of there work the fans and they vagate in half, and also when the car is long on you start flying the acceleration of the aspiometr to the point of turning off the car.
Po If someone can help me how to adjust the temperature so that it does not pass more than half and to verify if the acceleration problem is why. Thank you.
16 years 1 month before #9484 by manual-mecanica
Manual-Mecanica Response on the Re: Nissan Altima 93 Temperature
Hello partner, control the thermostat that may be failing and check that the electrventillator bulb connects to the fair point, luck and greetings.
16 years 1 month before #9487 by manual-mecanica
Your car is equipped with a computer or conventional carbon, I have to say to tell you where to look for
16 years 1 month before #9506 by manual-mecanica
Yes, my car is computerized and all electric
thanks
16 years 1 month before #9508 by manual-mecanica
So most likely if you have no problems with the blanket packaging, it is that the bulb is in poor condition, if you do not have the temperature sensor, what happens to your car schens To more than 2000 when the electro -ventilator is paart?
