Scenic switchboard
16 years 1 month before #9363 by manual-mecanica
Scenic Center published by Manual-Mecanica
Good I need to know how to reprogram Centering Scenic II Change Filter Gasail for the first time with 55000 km as it is changed normally I remove the air from the circuit and when I start it I get the service witness "Review injection" starts and works but it has no strength does not pass 90 km I need help I do not know what I can do
16 years 1 month before #9368 by manual-mecanica
Manual-Mecanica Answer on the Re: Scenic Center
What model is the Scenic to appear from that I can tell you what your problem can be
16 years 1 month before #9370 by manual-mecanica
Having if you can help me is a Scenic 1.9 130 hp dci 2008 how can I update switchboard how I can have the program and cable for this model thank you very much
