Party engine - Zetec 1.4 16v
16 years 3 months before #9299 by manual-mecanica
Party engine - Zetec 1.4 16v published by Manual -Mecanica
I would like to know where the temperature and speed sensors are located this engine, it is a CLX Model 97 party. I have the problem that it is accelerated in 2000 rpm and 3000 rpm. I know I can be the IAC, `but I would like to know where the other sensors are.
THANK YOU
AHHH I AM NEW IN THE FORUM:)
16 years 3 months before #9303 by manual-mecanica
Manual -Mecanica Answer on the Re: Party Motor - Zetec 1.4 16V
The temperature sensor is normally lodged in the water couplet or in the butt, and the speed is in the gearbox.
16 years 3 months before #9309 by manual-mecanica
If generally, but I want to know the exact position, it is hidden somewhere, at first glance it is not seen
16 years 3 months before #9313 by manual-mecanica
Hello friend, as Kikemec says the speed sensor is housed in the speed box, it is an integral part of the velocimetter transmission and the temperature sensor is in the thermostat, luck and greetings box.
16 years 3 months before #9318 by manual-mecanica
To all this I tell you, take out the IAC ... Clean a bit without disarming with W-40 unfortunate the + battery edge ... and after a while connect and Andubo well ...
