Change box lever lock
16 years 2 months before #9246 by manual-mecanica
LEVER BLOCK OF THE CHANGE BOX PUBLISHED BY MANUAL-MANICA
Greetings to all, I want to make a consultation regarding the Ford Exhaust vehicle automatic transmission, which I present a fault, when the change lever is parked and does not allow any movement to be made, the button that allows you to unlock the box to make the torque displacement towards D cannot be oppressed is blocked.
Who knows this vehicle and has the answer will be able to thank.
16 years 2 months before #9249 by manual-mecanica
Manual-Mecanica response on the re: lock lock of the gearbox
You have to step on the brake to unlock the button in the end of there to check
16 years 1 month before - 16 years 1 month before #9397 by manual-mecanica
Thank you for the subject, it was effectively damaged, the brake pedel swichet that lights the lights traceras and for this reason the gear lever, change and problem solved is blocked.
Greetings
Latest edition: 16 years 1 month before by .
